    Results 1 to 11 of 11
      Dublin, CA
      Just Laid Down Some Mass Load Vinyl
      My VA condenser was leaking, so I had to pull the carpet again. The seat were already out as I needed to make new mounts to angle them higher in the front, so I figured it was a good time to finish the sound deadening process. I have been looking at MLV products for some time, but could not justify the price that most vendors are charging.
      As I had some closed cell foam left over from the door panel project, I started looking for a roll of MLV. This stuff is extremely heavy, shipping tends to cost as much the product, so the trick is to find it locally. I found a company in San Francisco called Bay Area Noise Control and picked up a 100 sqft roll and one roll of seam tape this morning.
      I did the floors, but still need to do the rear wheel wells. The MLV is heavy, but surprisingly easy to work with. Hear is how the floors went:
      All painted with ZeroRust
      Two to three layers of dampner
      1/4" closed cell foam, I did not put any on the tunnel as the center console was already having clearance issues
      Finally the MLV and seam tape
      Now, if I could only get the LT1 to start...
      Brent
      1971 Camaro, LT1, 4L60E
      Normal, IL
      Very nice!
      oshawa ontario
      nice!....be sure and do an update when you get the car running again and let us know how well it works.
      D
      89 Iroc 406 Fitech 5 spd
      31 Scarab 2 x 454
      Mar 2010
      Orlando, FL
      talk about over kill. after all that you shouldnt be able to hear anything coming from under the car. probably dead quiet with with flowmaster 40s, lol
      Rustburg, Virginia
      LOL...don't forget to shorten up the throw on the gas pedal by at least a 1/2" more ...LOL
      Dublin, CA
      Quote Originally Posted by John Wright View Post
      That is probably about right :-) I pulled off the jute from the carpet over the hump, so the console sits at about stock height. So far everything has gone back together, but since I have a bit of wiring left and the refrigerant lines for the Vintage Air unit I am waiting on the lower dash panel on the passenger side.
      Brent
      Jul 2007
      nw phx
      hey Brent, good to see the car again!! really liking the wheels, do you have any pics of the car with the new wheels on and not in the trailer? email me a couple if ya could
      ...life is too short, live for today, tomorrow isn't guaranteed
      Dec 2002
      Philadelphia/New Jersey
      Now thats alot of deadening
      Looks really good,what kind of dampener is that you laid down first?
      Rockford Illinois
      That is what every convertible needs to keep the floor from getting wet. Done right you could get it to flow out the rocker before it got under that,lol. That is like a floor condom !
      Dublin, CA
      Quote Originally Posted by kustom71 View Post
      I used eDead which I bought in 2005. They have much better stuff out now, but I bought somewhere around 300 sqft at the time... always the problem with long-term projects!
      Brent
      Dublin, CA
      James, I don't have much more on the wheels other than what is posted. With the baby I rarely get out to the garage to work on the car. I have the front on the engine tore down again as I can not seem to get the thing to start. As by now everything is new I am guessing that I did not have the timing quite aligned on the sprockets during the rebuild. Once that is done, I just need to finish building the A/C hoses and e-brake cables, find a steering wheel I like and it should be ready to take to DMV for inspection. At this pace that should be two more years :-)
      Brent
