View Full Version : Door handle problem
bearcat
09-07-2010, 04:45 PM
69 Camaro, marquez design door panels, no binding on the inside.
When you open the door from the inside, the door handle doesn't snap back. You have to push on the handle to get it down.
Is this an adjustment issue? Are the latches bad? It is consistent on both sides.
Thanks for the input!
https://static1.pt-content.com/images/pt/2008/03/progress-1.gif https://static1.pt-content.com/images/pt/2008/07/edit-1.gif (http://www.lateral-g.net/forums/editpost.php4?do=editpost&p=304747)
09-07-2010, 08:41 PM
be sure your rod isn't touching the door or panel when panel is on. does it do it when its removed?
bearcat
09-08-2010, 04:13 AM
It's not hitting anything
