    Results 1 to 3 of 3
      Feb 2008
      Scottsdale, AZ
      Door handle problem
      69 Camaro, marquez design door panels, no binding on the inside.
      When you open the door from the inside, the door handle doesn't snap back. You have to push on the handle to get it down.
      Is this an adjustment issue? Are the latches bad? It is consistent on both sides.
      Thanks for the input!
      May 2002
      Northern California
      be sure your rod isn't touching the door or panel when panel is on. does it do it when its removed?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2008
      Scottsdale, AZ
      It's not hitting anything
