View Full Version : Kwik Performance ac bracket LS1
crustysack
08-03-2010, 03:01 AM
Just installed my Kwik Performance ac relocating bracket for an 02 LS1 into a 65 GTO- Talk about a great product- Well made, clear directions and looks great- Install took about 35 minutes. One of the few products I have bought for this project that needed ZERO modification to install- thanks Kwik Perf
sunkistcamaro
08-03-2010, 10:52 AM
looks like a really nice setup.
Thanks for the pic
ProdigyCustoms
08-03-2010, 10:53 AM
Awesome piece, we are selling quite a few of them
dipren443
08-03-2010, 02:36 PM
Should I assume this allows you to run the rest of the stock drive accessories for an LS???
Andrew McBride
08-03-2010, 02:41 PM
yes, it will allow you to run stock components. Some guys have used the stock location for the compressor, but it requires notching your frame.
I think the kwik performance piece looks great! Thanks for posting.
dipren443
08-03-2010, 02:48 PM
Yeah, thats what I figured. I know on F bodies that the frame notch is necessary. I honestly haven't been digging a ton on the little bits and pieces available for LS swaps, but this is a nice little piece. I am not a huge fan of the frame notch (doesn't look super serviceable to me) and this saves buying an aftermarket drive setup.
I like it!!!
Chicken Louie
08-04-2010, 10:21 AM
What are you running on the other side accessories? Did you run The factory GTO brackets? I have been looking at the Kwik stuff but not sure if I like the position of their alternator power steering set up?
crustysack
08-04-2010, 02:58 PM
I am running the stock alt +power steering set up off of the LS1- it is a little tight but there is enough clearance- I did have to replace the steering rag joint with a u-joint but other than that nothing else
