    Results 1 to 5 of 5
      Nov 2009
      AR
      Backspacing on 72 Pontiac LeMans
      SC&C Stage 2 up front, factory rear end. Front disc brakes, rear factory drums Vari Shock single adj all way round with SPC sport springs...
      245/35 or 40 up front (maybe 255) & rear will be 275/35 possibly 295/35 depending...
      18 x 8.5 wheel in front 5.5" offset
      18 x 9.5 wheel in rear 6" offset
      will that work?
      or should I go with a 5" front offset & a 5.75" in the rear?
      here is the wheel I'm looking at:
      http://www.summitracing.com/parts/SUM-142-8961GM12/
      http://www.summitracing.com/parts/SUM-142-8861GM20/
      Thanks!
      1972 Pontiac LeMans Luxury
      Nov 2009
      AR
      Ok I've purchased:
      18 x 8.5 with 5.5 bs front (back order from Summit)
      18 x 9.5 with 5.75 bs rear
      In a debate now...
      Talking to Ponchopwr he says 18 x 8.5 with 4.75 on the front as that will not hit the front swaybar & that the 5.5" wheel will (he has a 70 lemans sport)
      Roadbuster believes that 4.75 will give a more narrow looking wheel in the back than the front & should go with the 5.5 so the front won't look deeper than the rear. He owns a 68 GTO... He is also measuring his 17" wheels for me....
      I GREATLY appreciate both guys for going ABOVE & BEYOND to help me out....
      Anybody have thoughts on this issue?
      Mt.Pleasant Pa.
      I have 17 x 8 on the front with 4.5" bs
      17 x 10 on the rear with 4.75" bs
      1971 olds cutlass 442
      71 olds cutlass supreme convertible
      07 dodge ram
      96 monte carlo
      11 dodge challenger
      http://www.fquick.com/724TIM
      http://s297.photobucket.com/albums/mm206/724tim/
      Nov 2009
      AR
      Ok contacted Summit and changed the fronts to 4.5 bs... All should be well now...
      Jun 2009
      N.Nevada
      bs
      your 5.75 bs will be perfect and you'll be able to run a large tire too.
      462 Doug Nash 5 Speed Centerforce Clutch Quicktime Bellhousing Edelbrock Heads Solid Roller Holley HP Victor Intake Pump Gas 66 12 Bolt Poly Bushings Hotchkis Springs Metco Control Arms Big bar front Stock rear bar INTRO 20's & 19"s
