Results 1 to 7 of 7
Thread: AC Clutch Squealing
06-10-2010 #1
AC Clutch Squealing
I just installed a Vintage Air Gen IV system in my car with a Sanden compressor and March serpentine belt pulley set-up. I put a vacuum on the AC system for 25 minutes and then put a 12oz bottle of 134 to the low side. When the compressor came on it just began to squeal as it would slip. It would only get worse with higher rpm's. The belt is tight.
Will the compressor slip until it is fully charged? I did have to remove the compressor from the system to pull the motor before I had the chance to charge it when my cam went, so some oil was lost, but only about a tablespoon. Should I just bear with the noise until the charge is higher? I don't want to ruin the compressor, so I just turned the ac off and came here for advice.Dave @ Camaro Specialties
http://camaros.com/
06-19-2010 #2Is it possible that a safety switch in the system is turning the clutch on/off since the system (both sides) are low?
http://camaros.com/
07-05-2010 #3
