View Full Version : AutoCad 3d question (using inventor 2010)
modular93fox
05-17-2010, 11:58 AM
What Im trying to do is flatten a "loft"-ed part. I should have saved my design instead of closing it but imagine a back yard deck, and it has a 4x4 on each corner, and then a roof... not hard, but to add some pazaz to it, we cut some right angle triangles out of some 2x8 and put them on the 4x4 at the top, so it looks cooler
autocad 2010 aint got nothing on that... anyway its like that on each side of the deck. and what i lofted was between the 2 "triangles" and put a rail to define the shape i want. basically it looks like a cone. Exactly what I wanted to do in 3d, but i could not flatten the lofted part to a pattern i could print and transfer to some white translucent plastic. Trying to rough do this by hand would be a super frustrating.
Anyway, do you know how to flatten a lofted part.
tonight i will re do my drawing and post up a real picture in 3d.. :)
thanks,
clint
modular93fox
05-17-2010, 05:57 PM
https://static1.pt-content.com/images/pt/2010/05/lightcover-1.jpg
I tried to make the wood parts wood and the clear part clear but I failed. Im sure you get the idea... still cant figure out how to flatten the dang "loft" part...
thanks,
clint
Samckitt
05-17-2010, 06:01 PM
I can do it easily in NX (Formerly Unigraphics), but no idea in AutoCAD. Send me an IGES, or DXF of it & I can flatten it for you.
astroracer
05-19-2010, 04:02 PM
If you give me the dimensions I can create a sheetmetal part in NX that I can unfold. I can give you a flat pattern off that.
Mark
Samckitt
05-19-2010, 04:15 PM
Mark, You use NX also? Cool.
modular93fox
05-19-2010, 06:55 PM
wicked cool guys, it seems i probally was breaking sheet metal rules... still cant figure it out so I will take measurements on the actual length of the triangles sunday.
thanks,
clint
astroracer
05-22-2010, 06:49 PM
Hi Scot,
Yea, I've been running UG (NX) since 1993. Started on Version 9 and am now running NX5 at work.
Mark
Samckitt
05-23-2010, 04:44 AM
Hi Scot,
Mark
I started on V9 as well back in 92, I am now using NX6, 7, 7.5. I work for the company that produces it so I need to know it all.
Scot
LateNight72
08-27-2010, 07:35 PM
just make a new sketch and cut (via; extrude) the triangles off.
modular93fox
09-01-2010, 01:54 PM
I dont follow.. so i have the 4x4 in the picture, the 2 triangles. what do i extrude/cut? i have to make the loft, but when I do, I cannot flatten it.
modular93fox
09-19-2010, 05:58 PM
still cant figure it out. i'd like to "do it myself" that away I can learn how to do it.. dang this stuff is hard when you have no training.
thanks,
clint
