    Results 1 to 7 of 7
      Sep 2009
      LA,CA
      mini tubs/ New gas tank?
      i got a 69 camaro, I was looking at getting minitubs so i could fit some 335 under there. when i was looking at the DSE site to buy the minitubs but it suggest you purchase a smaller gas tank for $800+ for clearance im assuming. can anyone answer is it a necessity that u get the smaller tank or can u just use the stock gas tank? thanks
      Massachusetts
      u dont have to buy a smaller tank... but it is very necessary to notch the corners of a stock tank. the offset of the shackles will hit the tank when they pivot.
      Myself and a friend just bought new tanks (to avoid fumes when welding) and scalloped the ends closest to the filler neck and bent up a piece of metal to fill it. Hope this helps.
      CAN YOU BUILD PROTOUR ON A BUDGET?! NOT!
      Time isn't something you have!
      It's something you make!
      Aug 2003
      Orlando, FL
      If you are using leaf springs (which I would highly suggest you do not use leaf springs) you should use a narrow tank as the spring move inboard into where the stick tank resides.
      if you use a 4 link, you need only to notch the corners for tail pipe clearance.
      Feel free to call me for any clarification
      Apr 2010
      ct
      i just finished installing the dse mini tubs. i went with a fuel cell in the trunk. i also move the springs in board and used sliders
      so the springs are straight and the sliders work better. but my
      car is a street strip car. handling is not an option but can be changed later. 10 in w x15d rim and a 12in w tire. but the cell is nice in the trunk. just a suggestion good luck.
      Sep 2007
      Montgomery, Tx
      Is there anyone that sells a stock type tank
      modified for offset shackles?
      Anyone have pics or more details of tanks they have done?
      What is a fair price for having the work done?
      Gary Rys
      69 Camaro
      Aug 2003
      Orlando, FL
      Quote Originally Posted by GaRys69 View Post
      Not that I am aware of. We sell a lot of Ricks Stainless tanks can be bought narrowed.
      What kind of done.
      Sep 2007
      Montgomery, Tx
      HTML Code:
      What kind of done.
      Having a stock tank modifed to to clear offset shackles.
      Gary Rys
      69 Camaro
