Results 1 to 5 of 5
05-08-2010 #1
Low cost wheels for a mini tub camaro... Options?
Looking for an inexpesive but nice option... think i might of found an option but I dont know what backspace..
Detials.. 67 camaro Mini Tubs.. Oem subframe with spc arms and ATS coil over conversion.
I al looking at these http://www.newstalgiawheel.com/wheel...ubcat3=1011109
18 x 9.5 rear backspace..? Not a big lip fan.. like symaitry instead
17X 8 or 17x9.5 front? on oem frame... backspace?
I am open on tires but want the tires to tuck under the lipFrom a place you will not see comes a sound you will not hear....
67 Camaro In progress
05-08-2010 #2
- Join Date
- Jan 2005
- Location
- Dallas TX
- Posts
- 1,633
If you are mini-tubbing why not 11" rears? Also if you are willing to spend that much Intro's are not much more
05-08-2010 #3Well I guess I should explain a few things... I am only mini tubbing because my shock towers and inner wheel wells were shot.
I really don't like the look of those big lipped almost pro street wheel tire combos that are populat on PT camaros
I do like the nastalgia road racing look.
Also I am going to be using a Protigy Bar / G link so I have the option of a longer housing as well.. its a bit or a science project but will be a bit differient the most.
So what i was looking at is those Cobra Rims which are only offered in 9,5 which I think will be pretty good. I may be able to get the low under the lip look I am looking for which is tougher on the 67/8 then on the 9
And I think 17 limits your tire options..?Last edited by XLexusTech; 05-08-2010 at 07:30 AM. Reason: add detail
05-08-2010 #4Vintage wheel works 17x8 and 11.
Nathan Shaw
71 Nova, 1000+whp 5.3, 8 second autoXer.
05-08-2010 #5From a place you will not see comes a sound you will not hear....
