    Results 1 to 6 of 6
    Thread: Diode for Coil
      Feb 2007
      USA, TN
      Diode for Coil
      I'm putting a one-way diode on my coil. I need to know if a 6 amp diode is large enough. If not, I can put two in parallel.
      Marshall , MO
      Why?
      Brad Shepard
      69 Malibu
      Marshall, MO
      Central CA USA
      I tested an HEI and it drew around 5 amps at low speed but got near 10 amps at higher rpm's. What's the diode for???
      David
      Feb 2007
      USA, TN
      Quote Originally Posted by David Pozzi View Post
      David
      I have a lot of noise in the electrical system that is caused by the ignition system. It is interfering with the low speed operation of my Autometer speedo. I plan on putting EZ-EFI in the car in a week or two so I need to do something with this circuit. Unhook the tach and the speedo works great.
      I hoping the diodes will help. Cooper/Bussmann makes mini-fuse format diodes in 3 and 6 amp ratings. I'll put two 6 amps in parallel. That should be sufficient. Plus, if one goes bad, I'll have a backup.
      Marshall , MO
      I don't think the diodes are going to help with that. Try isolating the grounds for the tach and the speedo.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Feb 2007
      USA, TN
      Quote Originally Posted by shep View Post
      That's a good idea. They do share a comon ground.
