    Results 1 to 5 of 5
      Sep 2004
      Kansas
      Stock Frame Idea
      Ok dont flame me but I was wondering if it would be possible to cut out the center support on the front sub frame where the engine mount and where the basic suspension and build a kmember like they do on fox body mustangs?
      Greeley, Colorado
      You mean as in a tubular piece? It would certainly cut down on some of the front end weight. If it was engineered right I wouldn't see why this wouldn't be a good thing.
      Jason Mounce
      1969 Firebird | 2008 Corvette Z06 | 2008 Mustang GT/CS
      IL/TN
      that would not be stiff enough, too many bolted pieces, if it was a unibody that would be ok.
      https://www.protouringf-body.com "doing what they say can't be done"
      Sep 2004
      Arizona
      Banks turbo 69
      Check out the turbo 69 that was built at Gale Banks shop.
      They set the engine back and made a removable center cross member that could be removed to change the pan or inspect bearings and such. The entire car is quite a piece of engineering. But yea, you can cut up anything. http://www.bankspower.com/camaro-Framework.cfm
      May 2002
      Northern California
      you beat me to it.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
