    Results 1 to 7 of 7
      Solid bushings in rear frame rails?
      I'm alsmot done installing GW del-a-lum bushings in the rear of my 69 camaro. I got the bushings pressed into the leafs and I put one in the left framerail, now for my problem. I have got the right one in about 3/4 of the way and can not get it to move no matter what i do. I fabed up a kind of press, out of a bolt and a few washers but I can't get it to go in any futher for the life of me. I am on my second bolt now becasue of over torquing wtf! Anyone else put solid bushings in and have any advice?
      Stuart Seitz
      Mar 2003
      Boringville
      take it back out, check for anything strange in the frame hole, if there is a bur or like grind it down, if the hole is just plain too big, take a flexible brake hone and put it on a drill and hone the hole out a little, mine went in too easy, i had to drill a hole in the frame lip and through into the delalum bushing and tap a roll pin in to keep if from moving
      May 2003
      Austin, TX
      the left one on mine went in real easy, with just 1/4" all thread and some nuts and washer. the right one was a real pain. the inside was a little rusted. i ended up having to use a 3/4" piece of all thread to get it in. it was real hard, but i managed to get it in.
      I checked before and during the install for "junk" and I got nothing, I pre-lubed the bushing and the inside of the hole. Is there such a thing and a hydrolic C clamp?
      Sorry i'm just a little frustrated now
      Stuart Seitz
      Mar 2003
      Boringville
      i think you should hone out the hole wiht a brake hone, they are like $12's at kragen and the shaft is flexible
      Atlanta, GA
      Be careful that you dont squish it, they deform easily. Also if you hone the frame out (which I also recomend) check frequenty so you dont go to big. I learned from experience on both.
      mike
      Jun 2002
      Long Island, NY
      Yody,
      Your signature pic is too large, 75x250 pixels is the maximum alottable size. Please resize it, we would appreciate it.
