New to Pro-Touring
- Aug 2004
- Vancouver Washington
- 11
Lower front control arm is not an A-Arm
Ok I guess this is a new forum for you guys and I couldn't quite find what I was looking for so I will make this my first question post
Front of car, my B-Body has upper A-arms but the lower control arm is not an a-arm. Its just a connection to the frame from the spindal then it has a bar that connects from the spindal side to the front of the car frame at about a 40 degree angle (not sure of what its called as I am still new to suspension).
Can someone tell me the pro's & cons of this type of suspension?
I am trying to determine if I can still use a modified geometry upper arm without the lower link changing geometry too much?
Depending on the answers I been considering modifying the frame myself to accept more common upper and lower control A-arms. I also noticed while reading one of my 3 magazines (hot rod, car craft, chevy high performace) that a mustang in one of these mags was turning into a pro touring and it used the same lower control arm with support bar setup I am discribing so I assume from that it may not be all that bad?
-TriX-
