    Results 1 to 8 of 8
      Dec 2007
      British Columbia, Canada
      Getting cotter pin through ball joint
      So as the title says, I have a question about getting the cotter pin through the ball joint. I'm have Moog 5108 ball joints and I have the nut tight, but it hasn't gone far enough to allow the cotter pin to go through. In the past if I've gone too tight, then the entire shaft starts turning and then I can't tighten it up at all so I ended up replacing them. At $38 each, I don't want to keep replacing them. I can get the cotter pin through one side, but it won't come out the other. Any advice?? Thanks in advance.
      Central CA USA
      The ball joint taper needs to be clean, no grease or dirt, same for the balljoint stud. Then usually a little pressure forcing the balljoint into the taper is all it takes to hold it enough to prevent turning. If the nut is bottoming out on the stud shoulder, then a washer should be used. But I've never needed to do that on a first gen Camaro.
      It is permissible to torque the nut a little extra to properly align the castle nut to the cotter pin hole.
      Fontana, CA
      Quote Originally Posted by David Pozzi View Post
      I have. No biggie though.
      Nick R.
      Apr 2004
      OKC, OK
      take a lead or brass hammer and seat the taper so you do not damage the tie rod, should give you another castlation or two and let the cotter pin go all the way through
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      IL/TN
      As Dave mentioned it is critical that the taper be in good condition, and clean, torque to spec, use a washer if the tapered stud pulls past the nut face, after torking to spec you may tighten it to the next window in the castle nut,do not loosen, dirty, worn out tapers, loose, insuficiantly torqued and overall poor fitting tapers are 90% of the time the cause of broken studs
      https://www.protouringf-body.com "doing what they say can't be done"
      So. Cal.
      Sounds like my problem I had with some spindles. The tapered hole was too small. I was lucky enough to have factory stock spindles still and measured the tapered hole. Sure enough, the new ones were small. Back to the company they went.
      Oh, and for the spinning ball joint stud. I have had to resort to an impact air wrench sometimes. Just to get the taper seated quickly so the BJ stud didnt turn. Just a quick tap on the trigger. Prolly not the preferred method. And once the pin was seated and grabbing good I was able to move the nut to the last hole or even cinch it down a lil to the next hole. Just a matter of getting the tapered pin to seat and grip. JR
      Jun 2006
      Katy,TX
      I found after torquing mine a couple of times the slots would end up in different spots and get me closer.
      Dec 2007
      Thanks for all the advice guys...this has been great. I plan on getting to them on Monday or Tuesday so this will help alot.
