View Full Version : 8.5"x18
Black67SS
09-19-2009, 04:24 PM
Will a 8.5"x18" wheel work on the front of a 67' Camaro?All I see are 8" wheels most people seem to use.
raf0419
09-19-2009, 05:44 PM
I'm no expert, but I'm pretty sure 8" is the widest you can go when utilizing the stock subframe. Of course an aftermarket subframe or a modified stock subframe would allow the ultimate in customization for wheel fitment.
class67
09-19-2009, 08:51 PM
Good answer....op, stick with an 8" wheel!!!
Black67SS
09-21-2009, 11:50 AM
Just out of courosity what gets in the way using a stock subframe.Does the wheel stick out to much towards the fender or does it rub/hit some where on the inside.I see some guys using newer vette wheels and such.
nicks67camaro
09-21-2009, 12:21 PM
I am running an 8.5 vette rim. I needed to use an adapter to make the rim work. You can use them but they could rub the frame rails under full lock.
neki67
09-21-2009, 01:17 PM
Running a 8-1/2" up front on my Camaro for years but it will cost you some turning circle. You have to make the stops a bit bigger otherwise the rims/tires will hit the frame.
