    Thread: 8.5"x18
      The most easterly point in North America,NL Canada
      8.5"x18
      Will a 8.5"x18" wheel work on the front of a 67' Camaro?All I see are 8" wheels most people seem to use.
      Feb 2009
      Gastonia, NC
      Country Flag: Puerto Rico
      I'm no expert, but I'm pretty sure 8" is the widest you can go when utilizing the stock subframe. Of course an aftermarket subframe or a modified stock subframe would allow the ultimate in customization for wheel fitment.
      Jul 2007
      Tracy, CA.
      Quote Originally Posted by raf0419 View Post
      Good answer....op, stick with an 8" wheel!!!
      Steve Martin
      67 Camaro RS
      66 Chevelle
      Just out of courosity what gets in the way using a stock subframe.Does the wheel stick out to much towards the fender or does it rub/hit some where on the inside.I see some guys using newer vette wheels and such.
      Jan 2007
      CT
      I am running an 8.5 vette rim. I needed to use an adapter to make the rim work. You can use them but they could rub the frame rails under full lock.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Running a 8-1/2" up front on my Camaro for years but it will cost you some turning circle. You have to make the stops a bit bigger otherwise the rims/tires will hit the frame.
