    Results 1 to 2 of 2
      Oct 2007
      Alignment Specs, Pinion angle GBody
      Hey guys, I havent posted here in a very long time but I'm hoping to get a little help from you guys on my alignment. I need to go get the car re-aligned and I'm wondering what specs it should be aligned to? The car is primarliy a street car with the occasional run down the dragstrip. Also what do you guys feel is the best pinion angle to set it to? I have ideas of my own but I would like to hear what the general concensus is. Thanks for your help and ideas! ----Jeremy
      Specs: 86 GN, 850HP, ATS spindles, 1" drop springs, boxed lower A arms, 36mm front swaybar, Moog replacement front bushings, SPC adjustable upper a arms, Hotchkis rear boxed lowers, 1 5/8" rear swaybar, double adjustable UMI upper rear arms, 1" drop BellTech rear springs, 245/40R18's front -315/30R18's rear.
      Jul 2008
      Bethlehem PA
      Jeremy,
      I just had my upper adj. A-Arms installed at Savitske's, and had an alignment and had the pinion angle set (first time since installing the Currectrac rear upper adjustable's). Check with Mark at SC&C to find out the settings. John
      John at SC&C
      Savitske Classic and Custom
      NEW # 610-381-6100
      '87 Buick Regal Turbo T - Since New
      Lots of SC&C, Fays2 Watts Link
      Boze Pro Touring wheels,
      Baer 13" Pro+ & SS4+
      Shaved door handles
      Custom S/S Exhaust
