    Results 1 to 9 of 9
      California City Ca.
      stainless steel welding
      i want to add some v-band clamps from my downpipe to the cat. can the stainless steel band be welded to steel tubing?
      Dale Hayes
      87 turbo t
      Jun 2001
      Orlando, FL
      You bet. Use stainless wire or rod for enhanced corrosion protection.
      jp
      ​John Parsons
      Jun 2005
      Quote Originally Posted by parsonsj View Post
      jp
      IIRC, 308 stainless is the best alloy for joining stainless to steel.
      Mathius
      California City Ca.
      thanks for the info
      Dale Hayes
      87 turbo t
      NY
      Quote Originally Posted by Mathius View Post
      Mathius
      Actually, 309 would be preferred for dissimilar metals.
      The needs of the many outweigh the needs of the few.
      Feb 2008
      Denver NC
      Er 312.....
      Jun 2005
      Quote Originally Posted by toxicz28 View Post
      Ok, that sounds right. I knew it was 8 or 9. It's too damn cold to go out and dig through my bucket and see what I bought back when I was doing this. I actually typed 309 first and edited. Goes to show that old saying, "your first answer is usually the right one" may have some merit.
      Never heard of using 312.
      Mathius
      st. paul mn.
      most definitly 309 is the rod you are looking for.reg steel filler rod will work to but will rust the stainless rod will also work but will crack later 309 is your best choice.:bsjerk:
      Southern Az
      No way it absolutely CAN NOT be welded together! Stainless and regular steel have severely different melting points! Stainless must be welded with AC current.
      Hahahaha, just kidding! Go for it, it's possible. I bet everyone will remember it's possible now!
      Micah Prudhomme
      http://www.conceptfab.net/ <--better site soon
      http://www.myspace.com/conceptfab <---Pics
