View Full Version : tire help
BaddestBuick
09-06-2008, 01:39 PM
I just got my new wheels, now im in search for tires, Im set for the fronts but need some advice on the rears... they are 19x10... I really want a 305 series tire but i dont think its recommended on a 10 inch rim?? If I cant get the 305 I'll go with the 285... anyone here run a 305 on a 10 inch rim without any problems? do they bulge out? any pics would be great also
Roger M
09-06-2008, 03:54 PM
I say go for it! Some people might say that a 305 is too wide for a 10" wheel, but i've seen 9" wheels with a 295 and it looks and fits fine. I have 18x9 wheels with 275/40s and i am going to upgrade to a 285 when i need new tires. i think the average size tire for a 10" wheel is a 285. I'm sure others will chime in here and give their opinions as well.
JayR
09-06-2008, 06:55 PM
You can fit up to a 315 on a 10 with no problem and you'll just have a nice bulge on the sidewall.
BaddestBuick
09-06-2008, 07:23 PM
Im looking for a 305 but cant find many options with the 19's I have... I wanted a 35 series for the rear 305 but can only find a Nitto 30 series (I wanted a 35 series) and i wanted a 40 series for the front.. I dont know if I want to go 40 series in front and 30 series in the back seems like too much diffrence... any suggestions?
JayR
09-07-2008, 08:15 AM
I know what you're saying and have had similar frustrations and it's simply because that's mostly a supercar size and they have little need for much sidewall with the exception of the Ford GT which ran a 315/40/19 which looks killer if your wheelwell can hold it. If you don't quite need that much, there's a nice BFG 295/35 that will get you really close to your height and width needs.
Here's a wheel/tire size calculator that is really handy for quickly comparing front and rear sizes but as a rule of thumb, be sure your front sidewall isn't bigger in inches not aspect ratio than your rears or the car will always look like it's going uphill.
http://www.rims-n-tires.com/rt_specs.jsp
Depending on your front width, the 40 series may be really close in sidewall height so don't instantly discount it because it's a taller aspect ratio.
BaddestBuick
09-07-2008, 05:39 PM
Thanks for your help JayR, I appreciate it! Yeah I knew when i bought that I might get into problems with the 19's because theyre mostly on BMWS, Porches etc... but i knew what i was getting myself into and i wouldent have it any other way... anywho, the BF KDW looks good but its a bit more then I wanna spend...I might get the Nitto Invo but to get the 305/30/19 in the rears ill have to get the 35 series in the fronts otherwise the front tires will be taller, plus I dont feel too comfortable with 35 series in front... the other option is to get the Nitto's in 245/40/19 Fronts and 285/35/19 in the rears that sounds more comfortable to me.... BUT I want those big 305's LOL, anybody here running 30 series tires? would you? this will be driven almost everyday....
JayR
09-07-2008, 07:19 PM
I hear you and as a designer and a wheel guy, I totally respect making certain concessions to nail the wheels and stance because it's the two most important things!
MonzaRacer
09-13-2008, 07:09 PM
Check out this niffty little tester http://www.rims-n-tires.com/info_specs.jsp?text2=Sample%202:%20Honda%20Civic%2 0wheel&sw2=165&ar2=70&bd2=13&rd2=13&rw2=5.5&et2=40&text1=Sample%201:%20Hummer%20H2%20wheel&sw1=315&ar1=70&bd1=17&rd1=17&rw1=10.5&et1=10&pageTitle=Wheel%20/%20Tire%20Size%20Calculator%20/%20Comparer
BaddestBuick
09-13-2008, 07:41 PM
Hey thanks, yeah I was on that tire caculator for awhile before I pulled the trigger on my INVO tires... I figured out that if i got the 305's in the rears, i would have to get 35 series tire up front and I wanted 40 series... so I got 285/35/19 rears and 245/40/19 fronts and very happy with them
