    Results 1 to 12 of 12
      Grommets or bulkhead connector for trunk mount battery?
      Which do you prefer and why? Is one brand better than the other for these parts?
      I have the MAD Enterprises kit, and a Painless wiring harness. He uses 4(I think) guage for the battery cable, is that good? It's smaller than normal though.
      EDIT: The 8ga wire is a primary power wire, not a battery cable. Mark at MAD recomends the 1/0 or similar sized for the main battery cables.
      Sorry for the confusion!
      But I still need opinions on gromments or bulkhead!
      Last edited by Rileys68Camaro; 02-26-2005 at 05:34 PM. Reason: Correct some bad info on my part...
      Dayton, Ohio
      Better Battery Cable...
      del
      Hmm, it must be like 8 guage in the kit then. It's pretty small.
      Yep, 8ga, I wonder why he uses so small of a cable.
      Dayton, Ohio
      The only reason is cost!!!
      del
      Jun 2002
      Benicia, CA
      2 O Welding Cable
      I used 2 O welding cable at $1/ft. It is very flexible and has handled the load fine so far. I used a bulkhead connector at the firewall after my grommet setup caused a short and a fire! I don't remember where I got the bulkhead, so try Summit/Jegs/eBay. I also used connectors that had the solder already in them, I just had to use a small propane torch to get them hot enough to install. I got them off of eBay too.
      I was going to do the optima route but chose to use 2 Odyssey PC680's instead (13# each, instantaneous cranking amps of 1360, can be stored for long periods of time, and many other great reasons). My setup is consists of the 2 small batteries installed at floor level and wired in parallel. In order to get the same from the optima battery line I would also have to purchase 2 6-volt versions and wire them in series, and the cost was twice as much, hence the decision to get the Odyssey's. I have heard that 1 PC680 is enough for some cars, but I wanted enough juice for any occasion...
      Jeff
      1971 RS Camaro: PAINKILLER
      Dayton, Ohio
      Grommets and stuff...
      del
      Pittsboro, NC
      Riley,
      If installing a battery in trunk and bulheads at firewall, put a 200a circuit breaker between it. You can buy the kind that have a manual reset switch for $20-25. Its cheap insurance in case of a short and can use it as theft protection by manually tripping the reset swtich. Also use a 50a maxi fuse between starter and wiring harnesss like painless wiring recommends.
      Dido on the quickcar cables. Very flexible.
      Jay
      Graon, more wiring? My wife is going to kill me....lol
      Okay, what part numbers or what should I look for at the local Checkers or parts store or electrical store for these?
      Well, I'm a retard. Mark at MAD does NOT use 8 ga for a battery cable. It's a primary power wire hooking to the juntion block to provide a good 12 volt source.
      He recomends 1/0 or similar cable for the main battery cables.
      Sorry for the confusion.
      Laramie, WY
      What ever you use. Always use a gromet where the wire goes through metal. It is a safety thing. I would use a good quality one. I use the good ones made by stinger they also will contract down to seal the wire.
      Tim
      89 Lincoln Towncar pro touring project ( new info found for handling)
      95 Explorer XLT OFF-Roader
      95 Chevy Suburban LT 4X4
      07 Harley XL1200L Low 08 Harley XL1200N nightster
      Would you vote for someone who doesn't stand up for the flag?
