    Results 1 to 17 of 17
    Thread: BMW rims
      Miami, Florida
      BMW rims
      Front 18 x 8" - 13mm / Rear 18 x 9.5" - 25mm - 5 on 120mm center bores 72.6mm and 74.1mm
      Does any one on here know if these will fit a 1970 chevelle I do not know about these back spacing. The look good in my opinion and for $599 I can find a better price.
      There are others on E-bay that look real good and the price is great.
      http://cgi.ebay.com/ebaymotors/Fits-...VW#ht_3972wt_0
      Snohomish, Washington
      there is a guy on here that has the same wheels on his 70 chevelle, I cant think of his name but try a search. All i remember is that its red..
      Matt
      Aug 2006
      fort myers florida
      Yes they will fit. I have been running them for 4 year's on a 70 chevelle. The rear's have a 1/2" spacer to better center the tire in
      the wheel well and i used 1/2" wheel stud's and cut them to length. I have done three power tour's and numerous shorter trip's and have not had any problem's.
      Miami, Florida
      Wayne.
      Thanks for the info. What rear tire size do you have? I would like a 295 if possible. Are you using a 35-40-45?. What about the front?
      Are you using a spacer or an adaptor?
      Thanks again for your help.
      I think those rims are killer, could we see some pictures of your car. I think I have seen it before did you post on team chevelle about power windows and locks?
      From the small picture I can see the stance and that is what I want my car to look like.
      Aug 2006
      fort myers florida
      The rear are 275/40/18, front's 235/40/18. the picture is in the thread LOWERED AND SLAMED.
      May 2007
      las vegas
      i have them for my 70 z28!!! i got the machined ones so cause i had plans of painting them... i stripped the clear off did a ton of wet sanding to smooth out the machine marks and lots of polishing to get a true polished look... also painted the center a charcoal color.
      pics of how the came...
      and of one wheel ive done.
      but fyi they are not as advertised... the box and website said
      18x8 13mm 18x9.5 23mm
      but wheels stampings are both et20mm front and rear andrear wheels are only 9"s
      but still for the price you cant beat them and they look great.
      AJ
      1970 camaro rs, z28:pro-touring?... i wish
      93 trans am
      Houston, Tx
      What is the name or style of this wheel? I looked on the link but couldn't find one. Is this a replica of a OEM BMW wheel? The painted centers are fantastic! Great job. BTW, 20mm = .7874"
      Miami, Florida
      M parallel is the name of this rim, what brakes are you running?
      I'm looking at C-5.
      California
      Quote Originally Posted by Paul_J
      I know they're OEM and I'm pretty sure it's on E34 5 series cars, but it may only be E34 M5's. They're BMW style 37's.
      Matt
      Jun 2008
      Thanks for all the info. how do i find the right off set for the wheels. im really looking at 18x 9's. how big of tires can i run. i want to tuck the rears in the fenders. One other question is where can i pick up the floating cone lug nuts the everyone is talking about.
      Miami, Florida
      http://cgi.ebay.com/ebaymotors/RUFF-...mZ250256444023
      Check these out they are 18x8.5 and 19x9.5 same bolt patter as a chevelle. Mieght look into this one if the back space is right 35 front
      45 rear
      May 2007
      las vegas
      Quote Originally Posted by 540' chevelle
      45 rear
      lots of backspace there... youll need adapters... so factor in another 325-350 bucks...
      AJ
      93 trans am
      Jun 2008
      BMW rims for a 72 Elcamino
      I see some poeple are running the BMW rims on the chevelles, but i talked to the local tire shop and they say its not possible. what are you guys doing to run them. I really like the ADR style.
      May 2007
      las vegas
      thats cause most "tire shop" guys are idiots...
      you just need get some that have the offset for a 5 or 7 series car (less backspace) you can use the ones for a 3 series but youll need adapters ..
      they probally said that cause the bolt pattern are note the same on paper...ours a sae and bmws a metric so to them they see that a ASSume they wont work... they are not identical but so close its perfectly fine to use them...its like a 10thousanths of an inch difference...
      AJ
      93 trans am
