Results 1 to 15 of 15
Thread: Which tires "tramline" least?
04-06-2008 #1
All,
I am getting ready to replace the tires on my Buick. I've rebuilt the front end with SC&C's Stage 2 Kit, replaced the lower control arm bushings, idler arm and sway bar end links. My wheel combo is in my sig. I am going to drop down to 235/45/17s in the front.
Even after rebuilding the front end, I am still getting some tramlining issues where the car wants to follow the traffic grooves. I am attributing this to the quite old Yokohama A520s on the car, so I am going to replace the tires.
I've searched but cannot find a specific answer to my questions - which tires don't exhibit the tendency to tramline. Oh yea, and since the Buick proves to be pretty hard on the rear tires, I am looking for a cheaper tire shat I won't mind replacing too often.
I am currently looking at the Fuzion ZRis. Does anyone have any experience with these or any other good recommendations?
Also, my alignment is set to SC&C specs.
87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
04-06-2008 #2
- Join Date
- Oct 2007
- Location
- ridgefield ct
- Posts
- 876
well they were on a completely different car but i had the fuzions on my vw and they sucked. the dry traction was mediocre (straight and on turns) and the wet traction was abominal. when i put on nokian rsi snow tires they performed better in all respects!!
but considering the cost they make a good throw away tire, so i'm putting them on my stock monte rims 'till i can get my c6 rims.
work in progress--for the next 10 years.
1987 monte carlo ss 383ci, 9.7:1, xe274 cam, vortec heads, 200r4, 3.73 posi.
04-07-2008 #3This is a tough question. I've found that some tires will tramline like crazy on some vehicles, but not at all on others. A couple things that I've found makes a big difference:
Toe
Camber
Sidewall height
Steering rack/box T-bar stiffness
My BMW uses 225/35R18 up front and 255/35R18 in the back with Michelin Pilot Sport tires. It tramlines like nobody's business...and these are OE tires for that car. Some freeways require constant attention and two hands to control the vehicle. Other bimmer owners report the same with those tires as well.
My Camaro uses 245/40R18 up front with BFG KDW tires and tramlining is very managable. Both of my cars use similar static camber and toe settings.Matt Jones
Mechanical Engineer
Art Morrison Enterprises
04-07-2008 #4
