Results 1 to 15 of 15
Thread: Which tires "tramline" least?
All,
I am getting ready to replace the tires on my Buick. I've rebuilt the front end with SC&C's Stage 2 Kit, replaced the lower control arm bushings, idler arm and sway bar end links. My wheel combo is in my sig. I am going to drop down to 235/45/17s in the front.
Even after rebuilding the front end, I am still getting some tramlining issues where the car wants to follow the traffic grooves. I am attributing this to the quite old Yokohama A520s on the car, so I am going to replace the tires.
I've searched but cannot find a specific answer to my questions - which tires don't exhibit the tendency to tramline. Oh yea, and since the Buick proves to be pretty hard on the rear tires, I am looking for a cheaper tire shat I won't mind replacing too often.
I am currently looking at the Fuzion ZRis. Does anyone have any experience with these or any other good recommendations?
Also, my alignment is set to SC&C specs.
87 Turbo T: Precision 5857 Billet Wheel turbo, PTE Turbosaver, Razor's Progressive Alky, Red's XP fuel pump hotwired, Accufab AFPR, TurboTweak 93/94 chip, Scanmaster 2.1, 9 inch K&N filter, aluminum driveshaft, 160 thermostat, 3 inch Terry Houston downpipe with dump, DMH electric exhaust cut-out, TH 2.5 inch exhaust with Magnaflows, RJC powerplate, torque strap, Dutt neck stock intercooler, LT1 MAF, Translator Plus, Digi-Tails LED sequential tail lights, Eaton posi, TA Performance rear end girdle
Simmons wheels: 17x8.5 front (4.32" backspacing) with 235/45/17s Vredestein Sessentas, 17x9 rear (4.75 backspacing) with 275/40/17s, SC&C Street Comp Stage 2 kit (adjustable upper control arms, Howe tall upper and lower ball joints, S10 Xtreme lower control arm bump stops), 13 inch Baer front brakes, S10 rear wheel cylinders
