    Results 1 to 13 of 13
    Thread: Has Anybody
      Connecticut
      Has Anybody
      welded the seam that conects the front fenders with the lower extensions. If so how difficult was it and are you happy with the look?
      Paul
      OK
      re:
      it has been done: I am considering going back and doing mine. that is the only piece on my car that has a seam. here is a 68 that has been done.
      http://www.hotrod.com/featuredvehicles/37900/[/URL]
      Apr 2004
      OKC, OK
      I plan to do it once I get that far.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Aug 2003
      Orlando, FL
      Yup, I will give you a finished pic tomorrow if I remember. they do look killer smooth
      Apr 2004
      OKC, OK
      Thats a killer stance Prodigy! That is about where my car will sit as well. How high do you have that set for mockup?
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Aug 2003
      Orlando, FL
      I assume you are referring to ride height. The rockers and crossmember are the lowest point on the car. We actually cut the front off and raised the front frame a couple inches since this pic as it was only tacked in here. All the fuel / brake lines, etc run through the frame, also the exhaust is run through the tunnel. It is a full chassis so there is no subframe under the car, and being a perimeter frame, the floors are not raised. The car basically will have a belly pan bottom. We can go about a 5 rocker stance which is really low, and still have decent suspension travel, however it is set up to ride in the center of the suspension and have full travel at 6 1/2" ride height.
      The car is on a rolling frame jig I built and is about waist high so it is at a good working height. That is an old pic, before the Florida hurricanes and commitments with my other business, so not much has happened. I will try to get some pics tomorrow, the fenders are done, as well as the roll bar. Now that Nubreeds car (the yellow 69 convertible) is off the rotisserie and painted, Prodigy can go on the rotisserie for under body welding and floors. It's ready for paint, just need about 40 hours under the car on the rotisserie.
      The wheels are Jagarangs, we used them for mock up. We will be putting slightly bigger wheels / tires, 285 / 35 /18 fronts and 345 / 25 / 20s. I like a bit taller tire on 67 and 68s with the round wheel wells. I am trying to get Kris to design something new for wheels.
      look for pictures tomorrow of Jagarang and Nubreed, both are coming along now that i am back in the shop.
      Mar 2003
      Make it big
      Do you have any pics of the 345/25/20's? how tall is the sidewall?
      -David
      Aug 2003
      Orlando, FL
      It is nearly a 28" tire, so sidewall is nearly 4", about the same as 26" 335s on 18" rims. It takes special tubs to fit 28" tall tires on a lower car. It also requires a backhalf as a standard notch and mini tub is not enough.
      Aug 2003
      Orlando, FL
      Better late then never?
      Here is a pic of Prodigy's fender extension finished for paint. We love the way it looks, We think it gives a cleaner look.
      Feb 2002
      Santee, CA
      Quote Originally Posted by F70t/a
      26.8" High with 3.4" of sidewall according to the calcs.
      Here's a couple pics of my Pirelli P-Zero's...
      That's a 1 gallon paint can next to the tire.
      On the car :
      Aug 2003
      Orlando, FL
      Who makes your wheels? Colorado? Only ones I could find to make the 20 X 12s
      The Netherlands
      Country Flag: Netherlands
      I had most seems welded...sorry no pics yet...I agree it will look a lot better
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      Feb 2002
      Santee, CA
      Quote Originally Posted by ProdigyCustoms
      Yup....Colorado Custom Lazaers. 20x12 in the back and 18x8 in the front.
      I got them from Curtis at www.curtsrodandcustom.com. They had the best price at the time.
      I originally was going to go with an American Racing wheel, but the widest 20 they had was a 10".
      ---Eric
