Results 1 to 11 of 11
Thread: Project P.o.s. Part 2
01-27-2008 #1
Thanks to all that responded to my 1st questions. You guys have been a great help in deciding how far to go on these repairs. Much appreciated!
Ok, I found a roof today at my local ecology self serve wrecking off a slightly newer 2nd gen. It’s in really good shape, inside and out for $120.00 + $100.00 for a guy to remove it. Sweet, that parts taken care of. I had him cut way below the A-pillars, actually taking a chunk of the dash with it as well as much of the upper sail/ ¼ panel.
Now, I’m wondering how much of it I will actually need to use.
Worse case, I will replace the entire roof with bracing and all, but really my roof skin is what is rusty. so I’m thinking I will cut out my existing skin so I can get a better look at the braces for rust etc; and will have access to previously hidden areas for blasting.
So, here’s my question: Should I plan to remove the entire skin at all the factory spot welds etc? Or can I just slice it and leave a “margin” all the way around, leaving window channel and door channels intact? If so, should I cut it at the edges of the channels on the 90deg. bends, or should I leave more of a margin than that. Would welding be easier at the edges, or on the flat areas?
I really don’t want to replace the entire roof section if I don’t need to as I am told that temporary bracing would be required so the car doesn’t twist out of shape. I do have welded in sub frame connectors and a 4 point roll bar mounted to rear floor and wheel wells, so I wonder if that would be enough or if I would need to brace it.
Here’s a link to my previous post for pics:
https://www.pro-touring.com/forum/sh...ad.php?t=38697
Thanks for looking, MarkMark
LS1- T56
under construction
"Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
01-27-2008 #2Update
Well, I had today to get something done to my junk, so I decided to just go for it. I'm in it for real now!
I left a good margin to weld to, but I don't know, maybe this thing just needs the whole top as rust is everywhere. It's all surface rust and is now accessible for blasting except the insides of the A-pillars. Here there is surface rust on the insides, as far down as I can see with a flashlight. I suppose these areas could be chemically treated.
Here's a few pics:
This shot is from the rear and shows A-pillar at the left
Any suggestions to save the roof are welcome, MarkMark
LS1- T56
under construction
01-27-2008 #3
- Join Date
- Jul 2005
- Location
- Marshall , MO
- Posts
- 699
I would wire brush what I could get at and use rust a converter or encapsulater on it. For inside the a A pillar you could put a rag on a wire dip it in the encapsulater and run it through.
Brad Shepard
69 Malibu
Marshall, MO
01-29-2008 #4
