    View Poll Results: Spare tire?
    Voters
    141. You may not vote on this poll
    • Yes
      49 34.75%
    • No
      92 65.25%
    Page 1 of 4 1 2 3 4 LastLast
    Results 1 to 20 of 72
      Washington, MO
      Who runs a spare?
      I really don't want to, too much weight... but understand the need on a roadtrip. Just seeing who runs one.. thanks.
      Northern Indiana
      No spare for me.
      I always carry my cell phone and my AAA card,.
      Scott
      G Force Designs Concepts #004
      "Quicksilver"
      1965 Mustang Fastback
      347/450hp FRPP crate engine,G Force T5
      SSBC 4wdb,Budnik M5's etc...
      SOLD
      2011 GT500
      Ingot Silver Metallic
      Stripe delete
      SVTPP/Elec. Pkg.
      Stock for now
      SOLD
      70 Pro Touring Nova
      572/620ho crate
      TKO 600
      DSE suspension upgrades
      SOLD
      Phoenix AZ
      My first thought was "Spare what" then I saw you were talking about tires. None for me, thanks for asking though!
      Jul 2007
      Calgary, Canada
      Voted yes but only on long distance trips....
      Dave
      68 Corvair coupe
      65 Impala SS
      64 Corvair Rampside
      62 Corvair Greenbrier
      Asst. daily drivers
      http://www.sourceboards.com/
      No spare in my car, But most long trips are with Dan (68 sixspd) and he runs a spare. Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      Jul 2003
      Anaheim Hills, CA
      I might measure a GTO spare and see how it fits as far at the calipers and heigth.. if it's a go (or I find some other type of space saver) then I will carry one in the back seat area on long trips.
      Around town I have the GM fix-a-flat kit and AAA Premium Plus
      1968 Track Rat Camaro:
      Feb 2007
      No spare.
      Build - Drive - Destroy - Repeat
      Jan 2007
      Phx, Az
      No spare.. but for a long trip I will have to figure something out.
      1973 C10,400sbc, Baer Brakes, 4 link,TOYO tires
      2010 Charger RT
      __________________
      Joe
      Florida
      No spare except when on long trips (over 2 hours one way) then I put a stock rally II with same diameter tire in. Low profile aluminum race jack and boards to drive the flat tire up onto so I can get the jack under the car. If you have trouble getting a jack under your car when its got air in the tire just imagine how hard it will be flat!
      The spare tire should be the same diameter as the rear so if you need to use it on the rear for an extended period your posi unit will live.
      John
      TuoCo, CA
      I have a GTO spare. Haven't bolted it on to see how it fits tho. It would be a long distance spare. I have 100 miles of "roll back" with Hagerty.
      Steve
      '68 Camaro - SBC, TKO600, 3.73 Moser 12-bolt, Speedtech, ATS-AFX, Hotchkis, Forgeline, Ron Davis and C5 brakes (Kore3), Holley Terminator TBI.
      Check it Out Here
      Bedford TX
      Quote Originally Posted by NOT A TA
      John
      That right there is some good advice. Im sure half of us have had to get the 2x4 out to get the car off the jack handle once or twice!!
      Justin, 68 Camaro Update:5 speed is in and neighbors are pissed!
      Walla Walla, WA
      No spare (did that last year - too much weight bouncing around in the trunk) so going to run flats and a credit card with a high limit to replace them if needed.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Indiana
      I have a full size spare mounted in the bed of my Elky. To top it off, it's a matching 18" Intro.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Delaware, OH
      I keep a '05-'06 GTO spare in the trunk. Fits well over the front and rear calipers/brakes and actually only weighs ~20-25lbs.
      http://www.danhardison.com/GTOSpare/DSC02881.JPG
      Sep 2004
      No spare, no jack.....No room!!
      Cell phone and AAA.
      Aug 2001
      Connecticut
      Quote Originally Posted by ProBell
      I figure that's why you keep asking me to go-- same rim and tire size! Lesson learned for all-- find a friend with the same size tires who carries a spare and follow them.
      1968 Camaro RS/SS, LS7 with Katech mods, T56 Magnum, C6Z06 Brakes
      1968 Camaro RS Convertible LS3/480hp/4L70E
      1962 Corvette 327-340hp stock
      1963 Corvette Split Window Coupe
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Rockford Illinois
      2 cans of fix a flat are required for 235 and up size tires in most cases. I have never had a spare and have actually driven 30 miles once as fast as I reasonably could to make it from one gas station that couldn't even get the tire off to patch it correctly. I filled the tire to 45 psi and when I got to the tire dealer I still had 15 psi.
      Slow leaks have been a bigger problem over the years for the most part,along with the time someone stole my caps off my valve stems and at 125mph I lost some air because the valve core got depessed by centrifugal force. So before doing any high speed driving always make sure you have the caps on tight!!!!
      Jan 2003
      Arizona
      Quote Originally Posted by dhardison
      I don't run a spare, but I felt pretty stupid driving down to Florida and then running Power Tour 06. 2700 miles with no spare. Luckily we had Jason Huber and his dad shadowing the pack with a flatbed.
      How does one go about getting a GTO spare without dredging thru junkyards. Is there a GM part number you can share? And does it look like I can drill the mounting holes to clear 1/2" wheel studs?
      Now that my ful cell is flush mounted in my trunk, I want one.
      ________________
      Steve Chryssos
      I never leave home without. Waiting on the side of a road(late at nite,in a nice car)for AAA to show,or a friend to help.OR carry a few extra lbs. and be on my way in 5 minutes.
      Camtender,Privateer by choice
      Member of Hot Rod Power Tour Long Haul Gang 03'
      Winner of the 2nd annual Pro-Touring.com Run Thru The Hills drag racing event sponsored by Musclerides.com 06'
      2nd in class @ Big Bend Open Road Race 07' http://www.youtube.com/watch?v=Nti3UarUwzU
      Record holder @ The Texas Mile 08' for 1st gen. camaros http://www.youtube.com/watch?v=lvEzlnnAB8I
      http://www.youtube.com/watch?v=6L0sYaMnni4
