Results 1 to 20 of 29
12-26-2004 #1
63 Nova cause Everyone has an F-Body
63 nova SS, EFI 383. Current suspension is Global West Multi-Leafs in back, and the front is as trick as can be for a lame stock nova suspension(Boxed A-arms, eccentric lock out, stiff springs and shocks, quick steering box, sway bar and discs but still lame nova geometry). Car will have a 6-speed and be a serious road race piece that will still get considerable drive time.
Could someone recommend where i could get a front subframe that encorporates chevy components and no ford junk. I was also planning on a 3 or 4 link in back till i read everyone here saying leafs are good, and I've seen people praising the trailing arm system from HTH. I am very confident in my fabricating skills but not as much in my knowledge of the capabilities of these differant systems. The front/rear clips will be tied together well with a cage and such. What is the best rear suspension for road racing and where might i find a kit for it? Thanks in advance for any help.
12-26-2004 #2you should register at StevesNovasite.com and ask around about the Deurango deuce. a road racing 64 that some members drive at some race in Mexico.. They have the setup and its not very radical.... It should do what you want and more....
12-26-2004 #3Check out Wayne Due's C4 Corvette front clips for Nova's. I have one on my 67. Could be just waht you're after.
www.waynedue.com
Ryan
12-26-2004 #4
- Join Date
- Nov 2002
- Location
- Georgetown,TX
- Posts
- 2,557
Not everyone here owns an F-body. Some of us went upscale and own an A-body. :3gears:
12-26-2004 #5Good to hear! Nice El Camino.
Originally Posted by USAZR1
Thanks to everyone else about front ends but what/who do you recommend for a rear clip?
12-27-2004 #6...cause Everyone has an F-body
I have an E-body (Buick Riv)
The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
Signed,
A driver who laps Big Willow at 1:42.6 in a 134hp BMW - and I am still considered mediocre.
12-27-2004 #7
- Join Date
- Aug 2004
- Posts
- 957
Leafs really can be good, but that doesn't mean that a well executed link system isn't better, or that is not worth the trouble. One serious issue with the leafs is the ability to adjust the system for various tracks, in order to alter the spring rate, well, you need to replace the springs. With a coil over setup, changing springs is relatively painless, and setting the ride height/corner weighting is also easy as a result.I was also planning on a 3 or 4 link in back till i read everyone here saying leafs are good
In my opinion, the early Nova's are highly desirable to turn into track burners. They are light, and can be made even lighter. One drawback is that there really aren't any serious road race suspension "packages" that you can buy and bolt on, including the variety of front sub's that I have seen. As with the offerings for other cars, they are more "hot rod" than they are road race, and that's being nice. Most of the setups that I have seen are MII derived, which in and of itself isn't necessarily a bad thing, but the spindle and hubs really aren't enough to make me comfortable enough to build a track car around. At least your car is light though, this helps in this area a lot.
If you are really serious about fabricating, and have sufficient tools, you can probably do as well, but most likely far better than what's out there, by building a setup yourself. The learning curve is very steep on the suspension theory though, but there are some very sharp folks here that can give you some good advise and answer some basic questions. Read every book you can on the subject, three times. Be forewarned though, it is a very slippery slope, you will most likely get sucked in like a few of us here that probably don't know when to say "enough!"
Perhaps one question would be, what do you "really" intend to do with the car? Street/open track events, or possibly racing under a sanctioned body? If it is the latter, planning up front is more critical due to the rules.....
Mark
12-27-2004 #8Mark,
MII spindles are surprisingly beefy. Spindle pins and wheel bearings are quite a bit bigger than what's on 1st Gen spindles.
But KPI is really steep (10.5* for OE, 12* for 2" drop) and Hub face is too far away from KP axis especially with aftermarket brake/hubs. Even with +32mm offset rims and super steep KPI, scrub radius is still 2.0" (@ 12" rolling radius). Also it's pretty short in height, so you need longer UCAs for good RC migration (but I guess this doesn't matter if RC lateral location should indeed be left undefined...).
This is the most important question IMO. If you're REALLY serious about track events and racing, properly-designed link suspension is worth the extra money and effort (and probably rear seat delete to go along) assuming rules permit such modification.
Originally Posted by Mean 69
But then again, it could end up as a poor setup if you don't do enough homework in advance, in which case, leafs are much better way to go - Not much floor cutting (if any), rear seats intact, no problem conforming to the rules, and you actually have to try hard to screw up the geometry.The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
Signed,
12-27-2004 #9
- Join Date
- Aug 2004
- Posts
- 957
I couldn't find the darned magazine, I really wish I could have read that article. I'd have to say though, based on what you and the others wrote, I am a bit suspicious of this design approach. I'll get my hands on a copy somehow. I think I am going to subscribe too!(but I guess this doesn't matter if RC lateral location should indeed be left undefined...).
As for the other drawbacks of the MII spindles, well, yes that stuff too, in fact, that is even more important. It "feels" like a 2" scrub radius is too much, though I don't have direct experience. Obviously depends on the weight of the car, the intended use, power steering, etc. Here again, when it comes down to it, the "hardest" part of getting the right geometry, economically, is finding the right donor spindle/hub setup.
These leave a LOT to be desired in my opinion too, by the way, but then again, my requirements are probably a bit different than most folks.Spindle pins and wheel bearings are quite a bit bigger than what's on 1st Gen spindles
Katz, I am not sure I have your e-mail, drop me a PM here or there, and let me know how I can get hold of you.
Mark
12-27-2004 #10Mark, PM will be sent shortly afterwards.
Right now, I'm not sure which one to believe. Conventional method obviously worked for me, but if there's more to be gained, I'd like to experiment. Looking at suspension on Formula 1 and CART cars, I don't see much difference in UCA and LCA lengths, which supports (kinda) this new theory. But then again, we're working on totally different platforms.
I just got subscription renewal notice last week. For some reason, the price jumped to $100+!! But the price advertised in the latest issue is still $80 or something...
On smooth street, 2" feels OK with good PS, but I think reducing it to 0.75~1.0" would increase steering stability. My Riv currently has 2.375" or something, and it requires a bit of correction on bumpy road. I don't think there'll be much difference on the tracks, but I suspect there'll be slight difference in grip due to less weight shift (there'll be less rise/fall effect of KPI and caster)....It "feels" like a 2" scrub radius is too much, though I don't have direct experience. Obviously depends on the weight of the car, the intended use, power steering, etc....
Couldn't agree more. I'm kicking around the idea of using C5 or S10 4x4 hub cartridge for my Riv, and build knuckles from 4130 plates and some DOM tubes and have them heat treated (I got the idea from seeing knuckles on Sean's Camaro). You can get those hubs for $150~190 each at RockAuto. Both of them have very shallow offset - hub face to the knuckle's machined face is less than 2", so you can move LBJs outboard quite a bit with shallow offset rotors....Here again, when it comes down to it, the "hardest" part of getting the right geometry, economically, is finding the right donor spindle/hub setup....The first step of becoming a better driver is to attend a track event, time yourself, and realize the fact you really suck.
Signed,
12-27-2004 #11
