Results 1 to 3 of 3
06-04-2007 #1
THM400 Capacity & initial fire up technique
i need to pick up some fluids for a motor/tranny that i just put back in. i have read that a THM400 has 5-6q capacity if just the pan is dropped, and 12q capacity if the TC is drained.
when i yanked it, it was connected to the motor, and pulled at an angle that was prob at least 45*. the fluid drained right out the a-hole into a bucket and i did not measure how much it was.
so, did i drain my TC, and how much should i expect to put in? also, what routine should i do when i fire it back up? will the initial fluid fill the pan, then the TC will load up after engaged so i need to do it again?
any help appreciated, thx.
