    Results 1 to 12 of 12
      Kiler wisconson
      Is 5 on 120mm the same as 5 on 4.75 bolt pattern..??
      Im looking at some very affordable BMW wheels on ebay.. and they are 5 on 120mm.. i believe 5 on 4.75 translates into 120.2 mm
      Will they bolt on and not rock or come loose?? has anyone tried this..?
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
      Mar 2003
      Lafayette, In.
      5x4.75 translates to 5x120.65 mm
      Nov 2001
      Sacramento Ca
      search for BMW wheels, you'll find loads of discussion on it. Basically, the difference is so minute you won't notice. many have done it. Have yet to hear of a problem lug nut wise. Be sure the bevel on the lug nuts you use matches the bevel on the wheel. They are beveled different for metric ones.
      Tony Langlois
      1966 Corvair Monza
      Utah
      I have 5 on 120mm BMW wheels on my 67 firebird no problems so far
      Kiler wisconson
      send me pics please... What size wheels did you use and what back spacing.. 67 firebirds use similar backspacing to my 84 camaro..
      Project JUST-N-SANE
      Mar 2003
      Lafayette, In.
      i think the only time i have ever heard of anybody having problems is when they switch their 5x120.65 wheels to 5x120 wheels.....back and forth numerous times, thus tweaking the lug studs back and forth and eventually breaking the studs off.
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Like Tony said, do a search on BMW wheels. There are plenty here using beemer wheels (myself included). I use 17x 8.5 front and 17x 10 rear thanks to a micro tub. Don't know the BS of the top of my head (installed them years ago). Once again, do the search and you will find the answers to your questions.
      Kiler wisconson
      Thanks guys.. now if i could just make up my mine on which ones i want
      Project JUST-N-SANE
      Farmington Hills, MI
      I run BMW wheels as well
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
      Had the rear wheels of yesterday, offset is 17mm. I'll leave the calculating part up to you.
      Jan 2007
      SOCAL
      so they will go straight on the car? I was told to use them too, but my car is going to be used on the track, are there safety issues?
      Quote Originally Posted by neki67
      Oooops, nearly forgot, I'm using a second gen. rear end (= 1" wider in total). So basically for a 1st gen rear end that would mean approx. 5mm offset.
