Results 1 to 6 of 6
Thread: Cooling a 200-4R ?
Pro-Touring Veteran
- Join Date
- Nov 2006
- Location
- Washington, MO
- Posts
- 2,363
Cooling a 200-4R ?
How crucial do you think a trans cooler is for the 200-4R? This summer I plan on some 200 miles trips and don't want to run into any issues... Should I run a trans cooler? TIA
Tony
03-24-2007 #2
- Join Date
- Jan 2005
- Location
- Netherlands
- Posts
- 1,012
always run a cooler . i have a deeper oil pan and a electric fan oil cooler atatchst to it as wel.80% of the auto trans failers is heat!!!
03-26-2007 #3
- Join Date
- Mar 2005
- Posts
- 24
So running it through the trans cooler in the radiator is not enough?
[email protected]
67 Camaro Silver w/327 Edelbrock Rpm Heads, Speed Demon Carb, Vintage Air Frontrunner, BeCool Radiator
03-26-2007 #4
Banned
- Join Date
- Aug 2003
- Location
- Orlando, FL
- Posts
- 8,745
That is going to depend on your transmission / car / motor package, and also you radiator. If the car is mild or near stock and the radiator is a good alimunum unit with a good transcooler built in, your fine. If it has a big converter (small size / big stall), or the car is heavy, a nasty motor, or a stock radiator, or any combination, a cooler might be in your future.
03-27-2007 #5
New to Pro-Touring
- Join Date
- Dec 2006
- Location
- Fillmore, California
- Posts
- 39
I ran a 200 R4 in my 73 Nova for almost 8 years. Took it out to the track a couple of times. I only ran it through the radiator cooler. No problems here at all. But the radiator was a new 4 core unit.
Take that for whatever its worth.
Jake
04-19-2007 #6
