View Full Version : Cooling a 200-4R ?
Tony_SS
03-23-2007, 06:13 PM
How crucial do you think a trans cooler is for the 200-4R? This summer I plan on some 200 miles trips and don't want to run into any issues... Should I run a trans cooler? TIA
Tony
Roadrage David
03-24-2007, 03:17 AM
always run a cooler . i have a deeper oil pan and a electric fan oil cooler atatchst to it as wel.80% of the auto trans failers is heat!!!
norcalcamaro
03-26-2007, 07:42 PM
So running it through the trans cooler in the radiator is not enough?
ProdigyCustoms
03-26-2007, 11:03 PM
That is going to depend on your transmission / car / motor package, and also you radiator. If the car is mild or near stock and the radiator is a good alimunum unit with a good transcooler built in, your fine. If it has a big converter (small size / big stall), or the car is heavy, a nasty motor, or a stock radiator, or any combination, a cooler might be in your future.
Gaslight
03-27-2007, 04:43 AM
I ran a 200 R4 in my 73 Nova for almost 8 years. Took it out to the track a couple of times. I only ran it through the radiator cooler. No problems here at all. But the radiator was a new 4 core unit.
Take that for whatever its worth.
Jake
Turbo T
04-19-2007, 09:24 PM
Let's put it this way, a new transmission cooler is much less $$$ than a new transmission, right? Cheap insurance, IMO. And no I'm not just saying that so you'll buy my cooler, haha. :look:
As someone already said, heat is the number 1 killer of automatics. Go to PTSXtreme.com (200R4 shop) and read up about it. I'm running a deep pan myself, as well as PTSXtreme's aluminum radiator. I bought a cooler to use with the stock rad., but then the rad. took a dump, so I killed two birds with one stone and got the heavy duty alum. unit. I will use an auxiliary cooler when I start racing the car, but money can be spent elsewhere for now.
(PM'd you Tony_SS, btw)
