    Results 1 to 3 of 3
      South Jersey
      Early Corvette rear vs. later model
      OK, since you guys got me into this, I need you to help me out on this one. When I started this project, a 68 Firebird Conv. all I wanted was a nice car. Then I started reading all the posts on Pro-Touring and decided that I needed alot more stuff. It started with the big Corvette brakes up front. Then came a mini tub. Then I figured that since I have to cut the frame rails (in questionable condition anyway) I might as well replace them with 2X3 pre-bent rails. Since I'm moving the rails, why not go ahead and put the full Corvette IRS in there. While mentioning to my neighbor that I'll be putting in a Corvette rear he say's that he's got one I can have. Problem is, it's from a '68. So my question is, should I use this rear or sell it and get a later model unit? What are the pro's & con's? I have to add that I'm doing all the work myself and having a blast, but each change in plans ends up costing more and pushing back the completion date.
      J. Clear
      La La Land, CA
      Sell it. Look for the C4 IRS rears for the project. I am doing a 96 Dana 44 in a 67 right now. The Wayne Due weld in IRS kit is a dream. This would not be as straight forward without it.
      Tyler
      Sep 2002
      San Jose, CA
      The 63-81 Corvette rearends are not bad pieces, but they do have flaws. There is a major geometry error built into the strut rod placement, it can be corrected for a couple hunderd bucks worth of parts, but its there. The rearends are not the strongest pieces, but if you blueprint the limited slip/ring&pinion they will take a ton of power.
      The halfshafts are a weakpoint, make sure you use u-joints without zerk fittings on them.
      The main bushing on the trailing arm needs to be replaced with a big spherical bearing to really work properly.
      The C4 rearend is a better piece but they have trouble with blowing out hub/bearing assy's. Plan on doing all of the bushings in the trailing arms, a wise man would use spherical bearings there as well.
      1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
      But ask me about my 2004 STi Auto-x car...
      Just call me Brett
