View Full Version : Who has C6 ZO6 calipers
Samckitt
12-02-2006, 04:29 AM
The ones with 6 pistons up front & 4 out back and has the calipers unmounted & can give me some dimensions?
Leadfoot1
12-03-2006, 07:11 PM
I do....
Just got ,em. Still on the table.
What do you need?
Lead
Samckitt
12-04-2006, 03:49 AM
The distance between the mounting holes, & distance from a line between those holes to what would be the centerline of the rotor.
thanks,
Leadfoot1
12-04-2006, 06:45 PM
5 1/16" and 1 1/2"
http://i138.photobucket.com/albums/q251/Leadfoot1969/DSC04856.jpg
Hope it helps.
Lead.
Samckitt
12-04-2006, 06:50 PM
What is 1.5" for? If you drew a line between the two holes you measured at 5 1/16" & measured from the centerline of the spindle to this line, what would that measurement be?
Leadfoot1
12-06-2006, 05:39 PM
It would depend on the mounted height of the caliper....And its not mounted. (cause when i drop the caliper over the rotor to mimic it i can't find the real mounting height point)
Sorry.
Maybe later when i feel like going to the garage and clean an old spindle (maybe over the week end)
Lead.
Samckitt
12-07-2006, 03:46 AM
I'm not sure we are talking about the same dimension. Send me an email & I will send you a pic.
Scot
[email protected]
Samckitt
12-07-2006, 04:52 AM
Here is the other dimension I was referring to.
Leadfoot1
12-07-2006, 05:49 AM
Sooooo,
As i was saying, i need to get the spindle attachment bracket ON the spindle in order to give you an accurate measure. Otherwise, the caliper is just "Floating" on top of the rotor and (can be anywhere- up or down.) i can't measure to the "center" on the rotor precisely. (I can use the center of the rotor to take my measure, its the placement of the caliper that i can't give you right)
I see what you need. I want to mock up my parts anyway to test fit and have an extra set in the garage i want to get to. I'll try and get that done this w-e just for you!
:smoke:
Lead.
Samckitt
12-07-2006, 07:27 AM
OK. Then it was I who was confused on what you were saying.
Sorry - thanks
ZZ4Blazer
12-09-2006, 04:28 AM
I've seen some posts about you being interested in the C6Z brakes to replace yours. If your C5's are mounted on the S-10 spindles, like they would be to factory specs on the C5 spindles, then I wouldnt see any problems.
