    Results 1 to 2 of 2
      San Diego
      Front end limiting factor
      Can those that have been there done that comment on this.
      I know the max front tire width subject has been beaten to death time and time again but I am looking for help with a different twist to this question.
      Specifically, I am referring to the 80's G-bodied cars (Monte Carlo, Cutlass, Regal, GN, etc..).
      If you're running aftermarket brakes, sway bar, upper and lower control arms, spindles, and 18" rims what becomes the limiting factor of wheel/tire width? Is it the frame, which I suspect, or is it something else that the tires contacts?
      If it is as I suspect and does in fact run into clearance issues with the frame (hitting when attempting a turn) are there any companies out there making a front clip for the 80's G-bodies that alleviate this issue? I see everything for the early camaro's, etc... but have not found any front clip's for the 80's g-bodies to address the issue of tire width clearance.
      I do realize that this is a very limited market and therefore most likely means there won't be any product base for this but I figured it was at least worth a try. To most this would not matter but there is always that ten percent like me that just have to make this hard. TIA
      Jun 2006
      Mountain Home,AR
      On a g-body you will run into outer fender lip clearance issues on the outside, and the sway bar on the inside. Also, they will sometimes rub on the inner fenders when really turning. If you hit the backspacing right you can stuff a decent sized wheel and tire on a g-body IMO. Some people remove the inner fenders to gain clearance, but that is mainly for height due to a massive drop in front end height. I wouldn't recommend this though (it makes the engine bay get real dirty and packs a bunch of air in under the hood at high speeds causing a lot of drag).
