    Results 1 to 15 of 15
      NYC
      mushy pedal wilwood brakes
      Hi i`m posting this problem for my buddy,he has a `70 Z28 just did his front and rear disc brake swap,got the Wilwood 4 piston calipers with cross drilled and slotted rotors,new wilwood master,new booster,new rear line kit from Precision brakes,new Wilwood proportioning valve,bled system but brake pedal feels mushy and when the brakes grab they grab real low on the pedal,any help and suggestions appreciated.
      Oct 2003
      Arvada, Co
      sounds like air in the lines
      Brian
      I have an unlimited budget. That bad part is I have already used it up.
      Auburn, WA
      I agree. Has to be air.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      NYC
      no air its been bleed 4 times
      NYC
      do you need bleed both top ports per caliper. the calipers have 4 2 at the top and 2 at the bottom
      Sep 2004
      Santee, CA (San Diego County)
      could be that the master cylinder is the wrong size. you want to bleed all of the top ports
      Alcino Manuel Azevedo
      76 Mustang II Cobra II
      Featured in April 2006 Popular Hot Rodding
      Quote Originally Posted by $Mike70Z-28
      Yes
      Could be the master isn't bled completely too. You can disconnect the lines and run tubes froom the brake line ports into the reservoirs and pump a bit to verify no bubbles are in the lines.
      Sep 2002
      So. Cal
      Just because you bled 4 times doens't mean you got it all. Mine was a pain as well. I still have a little air in the rear thats screwing with me. Wilwood says to bleed the master back to itself first. If not, you keep pushing air into the system.
      A Quick way to know if it air. If you pump the brakes and it gets better. or if you let it sit over night, does the first push go down to the floor? or more then usual. If so, Air is the culprit.
      Oversized lines can be an issue also.
      Otherwise I agree with the master.
      Ron
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Jan 2002
      Crockett, Texas
      Have you tried a gravity bleed?
      Don 67 Camaro RS/SS Texas
      Central CA USA
      Yes! air rises, bleed at the top.
      Feb 2006
      Elk Ridge, Utah
      [quote=ronracer] A Quick way to know if its air. If you pump the brakes and it gets better. or if you let it sit over night, does the first push go down to the floor? or more then usual. If so, Air is the culprit.
      Not to be a knowitall but this description is not in fact air its adjustment issues
      if you can pump a pedal up to the top then you are actually taking up the slack of loosley adjusted drum brakes or the possabillity that the pads are being sucked back into the calipers, or loose wheel bearings caliper mounts ect ect
      air acts spongy and cannot be pumped up
      I mean you no Disrespect as your car iz da SHIZZLLE
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Feb 2006
      Elk Ridge, Utah
      Oh and for crap sakes get this cheap tool you wont regret it
      Its an air operated one man brake bleeding system no self respecting car entusiest should be without. =)
      http://www.harborfreight.com/cpi/cta...emnumber=92924
      thier picture is horrible but it is basicly the same thing I got off a snap on truck
      69 Camaro
      Jun 2001
      Orlando, FL
      Or this:
      http://www.motiveproducts.com/02bleeders.html
      I bled my brakes from brand new, no fluid whatever. It took 30 minutes, and no helper needed. It works!
      jp
      ​John Parsons
      Sep 2002
      So. Cal
      Quote Originally Posted by Madspeed
      Yea that would be a correct statement if we were talkin about drums. Since he just installed Wilwood 4 piston disc's all around, that doesn't apply here.
      Now I think you have something by stating the pads getting sucked back into the calipers? Master Cylinder Issues?
      Oh and thx Snoop!
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
