    Results 1 to 12 of 12
      Apr 2004
      OKC, OK
      Pros and Cons of Satchell Link Rear
      Well, it didn't take much to throw out the Chevelle rear. I was already wavering anyway. I still would like to use a Satchell link rear just purpose built. I would like to discuss the benefits of this design in this thread. I don't think it has been discussed enough in order to make an educated decision about using it.
      Here is the limitations I have. Lower control arms will mount in the same location as the leafs mounted but with new mounting brackets. Frame rails have been straightened to 32" front to back. I have installed a 2"x3"x.187 crossmember right where the rear floor and trunk pan meet behind the seat (Look at might site for pics if need be). I don't mind minimal intrusion into the ****pit and along as it does not further hinder the rear seat.
      I understand basic suspension design and theory but get start to get lost when numbers become involved. I don't have a program to play with to help me in that area yet. Hopefully we can use this thread to come to a better understanding of the Satchell link rear end. Thanks in advance for your help.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      McMurdo Station, Antarctica
      From the old board
      Mike,
      Checkout http://66.70.234.198/forum/showthread.php?t=203
      Dennis started talking about the Satchell Link suspension about 3/4 of the way down the page. The first post about it was (8/4/04 5:35 pm).
      Hopefully that will help.
      R.J.
      Apr 2004
      OKC, OK
      I have read Dennis' thread on 3 link inside and out. It does not go into any real depth other than mentioning its possibilties. I have also searches CC.com and not much on Satchell over there either.
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      dennis68 Guest
      I thought that Preston built a Satchell on his Mustang, posted some nice pics. It came out real nice. I don't think he had any tech on it yet.
      Alta Loma,SoCal
      After looking thru some pictures I now understnd what the Satchell link looks like. It's the design many people use when doing a 4 link in the rear of a Rockcrawler truck/buggy. The main reason it is used is to reduce/eliminate rollsteer over upwards of 24"+ of wheel travel. Other than that it seems to be just a 4 link. Same bind problems if you use stiff bushings. I think it all comes down to just getting the links the right length, with the right bushings/bearings in the ends, and the positions above/below the axle.
      1965 Buick Skylark
      Oct 2003
      Arvada, Co
      Mike to clarify, as it is unclear, do you want to keep and use your rear seat?
      Brian
      Apr 2004
      OKC, OK
      Yes I want to keep the rear seat. Something about children wanting to go for a ride when finished.
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Oct 2003
      Arvada, Co
      Thanks Mike, I saw that in your other post. I just forgot to update this one.
      dennis68 Guest
      I knew I would find it, Jag over at c-c.com built a Satchell for his Jaguar, check it out. 10" RRCH is not too bad with a 100% AS.
      Apr 2004
      OKC, OK
      I have seen that thread in the past. However, when I just did a search over there, it did not come up for some reason.
      Another question. Is there any reason why I can't converge the upper arms instead of the lowers?
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      dennis68 Guest
      Converging the uppers sets the RRCH way too high.
      Poulan GA
      I've been searching and reading for 3 days. Has anyone succesfully completed a satchell in a 1st gen camaro. Should i stick with the idea or just go back to leafs?
