View Full Version : Heater Core Change out
Blue69Gen1
08-25-2006, 06:42 AM
I lost the heater core in my '69 Camaro last night. It is a SB with tall valve covers. The heater core inlet/outlet is very close to the valve covers. I would like to move the inlet/outlet to gain more room around the engine.
Is it possible to switch over to a BB heater core and cover to move the inlet/outlet closer to the passenger side fender?
I also noticed that Rick's sells a A/C evap delete heater core cover. It also looks like it would move the inlet/outlet towards the passenger fender. I assume that it uses the SB A/C heater core?
Any issues either method?
08-25-2006, 05:50 PM
Switching to BBC is very easy. Buy the heater hose plate and drill two holes. Then replace the heater core with a BBC one. You will have to modify the box a bit to fit the core correctly.
http://www.rickscamaros.com/cgi-local/SoftCart.exe/cgi-local/smpagegen.exe?U+scstore+ycgc3295ffd140d1+-p+-c+scstore.cfg+HC-12
Blue69Gen1
08-29-2006, 07:01 AM
Thanks for the info, it will be nice to gain some room by the valve covers.
