      Aug 2005
      Heater Core Change out
      I lost the heater core in my '69 Camaro last night. It is a SB with tall valve covers. The heater core inlet/outlet is very close to the valve covers. I would like to move the inlet/outlet to gain more room around the engine.
      Is it possible to switch over to a BB heater core and cover to move the inlet/outlet closer to the passenger side fender?
      I also noticed that Rick's sells a A/C evap delete heater core cover. It also looks like it would move the inlet/outlet towards the passenger fender. I assume that it uses the SB A/C heater core?
      Any issues either method?
      May 2002
      Northern California
      Switching to BBC is very easy. Buy the heater hose plate and drill two holes. Then replace the heater core with a BBC one. You will have to modify the box a bit to fit the core correctly.
      http://www.rickscamaros.com/cgi-loca...tore.cfg+HC-12
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Aug 2005
      Thanks for the info, it will be nice to gain some room by the valve covers.
