View Full Version : made me cry....
Rolling_Thunder
08-19-2006, 05:28 PM
Well I found the tire I want to run on the Charger... I was looking for an tire that fit an 18" wheel with a width of 335-355... and I wanted it approx 28" tall...
the only thing remotely close was this tire... 345/35/19...
I was really depressed when they said $690 each...
:guilty:
any other recomendations ?
I'm hoping to go with a 275 tire in front on a 17" wheel and a wide tire (335-355 on a 18" wheel)
72 GOAT
08-19-2006, 06:23 PM
If you go to www.tirerack.com (http://www.tirerack.com) (there is a link on the right side) you will find plenty of tire's in the size you want (335/30/18).
Rolling_Thunder
08-20-2006, 12:14 AM
335/30/18 is only 26" tall... i need 28" tall
ilovefirstgens
08-20-2006, 12:54 AM
345/35/19... I was really depressed when they said $690 each...
Well for whatever reason the link to the bridestones wont work so heres the link http://www.tirerack.com/tires/Compare1.jsp?width=345%2F&ratio=35&diameter=19&startIndex=0&search=true&pagelen=20&pagenum=1&pagemark=1&x=90&y=3&RunFlat=All
USAZR1
08-20-2006, 01:30 PM
Michelin makes a 345/35/18. It's around 27.5" tall.
Ralph LoGrasso
08-20-2006, 02:20 PM
More manufacturers (or at least one) need to make a 335/35/18 (preferably in r-compound). I'm convinced that is the ideal tire size for many a mini-tubbed PT car.
OHCbird
08-20-2006, 03:28 PM
Last Dec at PRI I talked with Nitto, Avon, Khumo, Goodyear, BFG, MT, etc- no one even sounded close to a taller (re:35/40 series) tire, as there aren't any OEM apps for it. The closest are some of the M&H and MT tires, but they're 'straightline' DRs. We don't need 25/30 series rubber for the ultimate in handling- many road-racing setups run a higher profile with a stiff sidewall.
I agree- If they made a run of 1000-2000 335/40/17's (and larger), they'd sell 'em out. The 1st gen just doesn't look right with anything smaller than 26", and that's pushing it.
Someone help us out!!!
lvrpool32
08-20-2006, 04:55 PM
Took me 6 months of searching ebay and racingjunk to find a pair of 345/35-18 Pilots.
Michelin make a 345/30-18 Pilot Sport Cup.
Nick
Rolling_Thunder
08-20-2006, 05:53 PM
yes... I think the Charger's lines call for a 28" tall tire in the rear... anything under that and it does not look right....
