ScotI
05-07-2006, 09:07 AM
I've been researching info on upgrading the stock disc/drum set-up on a 79 G-body. The car is street only; I just want to improve the brakes along w/the rest of the drivetrain. I'm trying to keep this low-buck as well......
I want @ least 12" front rotors but the B-body 12" brake swap is too controversial in the benefits vs. issues. I've been reading posts on the 'LS1' disc swaps w/a stock (or similar) G-body spindle & it seems like the avenue I'll pursue.
Since this is a budget build, I'm using some TT2's that I already have. They fit on a stock GM 12" brake set-up currently w/o issue (12" rotor;1/2 ton GM truck caliper;18" wheel). I've seen LS1 cars on the road w/TT2's so I'm guessing the wheels will work w/the LS1 brake swap.
Is anyone using TT2's? What brake set-up do you have? Any clearance concerns I need to consider?
