    Results 1 to 12 of 12
      DFW, TX
      Wheel Fitment for A body Olds.
      i'm looking into to 17" torque thrusts for my 68 Olds Cutlass. i wanting to fit the largest tire and rim possible out back without mini-tubbing. would it be possible to get a 315/40/17 on a 10" rim to fit easily?
      any offset suggestions?
      Thanks.
      I am not aware of that size tire. Maybe you mean a 315/35-17?
      Houston,TX
      Man just mini tub that beast already and throw some 345's on.......J/P. Heres a bump for ya hopefully, somebody on here will chime in..........
      71' Nova - LY6, T56
      Quote Originally Posted by NvrDun71
      A-bodies are not constructed like Nova's or Camaros. You can't just mini-tub it. Way more to it than that.
      Houston,TX
      Quote Originally Posted by andrewb70
      Didn't realize that man but makes since they are not a unibody car....... Thanks for the lesson. In your experience with A-body's what is the biggest wheel tire combo w/out wheelwell modification and stock width rear?
      71' Nova - LY6, T56
      Marshall , MO
      http://carcraft.com/techarticles/3636/index.html here is a place to start the article says 315/35 on an 11 inch wheel
      Brad Shepard
      69 Malibu
      Marshall, MO
      Sep 2004
      Southern NJ
      Matt
      1965 Pontiac GTO – Spotts 421 Tripower | TKO600 | 3.90s | Vintage AC | Baers | Hotchkis/SPC/BMR Suspension | Intro Vistas | BFG KDW Redlines | 06 GTO Seats
      With careful wheel selection and assuming that the body sits evenly on the frame (many times it does not) you can fit the 315/35/17. I run 295/45/18s on my GTO on a 10.5 wide wheel with 6 inches of backspacing.
      Houston,TX
      Hey Fritzsch...ck out the rim/tire specs and backspacing on the chevelle in this link:
      https://www.pro-touring.com/forum/sh...ad.php?t=18786
      71' Nova - LY6, T56
      DFW, TX
      ok guys, thanks again for the help... the wheel size im looking at is a 305/45/18 Nitto drag radial, on a 9.5" rim... im assuming the dimensions will still work due to being narrower than the 315/17's. i dont believe i will have any height problems. If anyone knows different please let me know.
      offset is.....
      minimum needed with 10s are 4.5... I should know I bought these froim an olds,thinking....A body=olds=chevelle==same same.. answere NO>>>> so you need 4.5 .
      DFW, TX
      so the offset on the 18"X9.5"s im going to buy needs to be 4.5"... ?
      thanks for the info.
