    Results 1 to 8 of 8
      Mountain View, CA
      Request for bodywork tutorial
      Wondering if some of the experienced folks here could put together some instruction pieces on basic bodywork skills.
      Some things that might be helpful for those that have never pounded out a dent and are looking to do some of their own prep work.
      Examples:
      Welding up a trim hole
      Hammering out a dent in a body crease (ie a door ding)
      Hammering out a dent in a flat surface
      Shrinking/stretching
      Filler/Glaze application and sanding
      etc
      Might be a handy thing to have as a sticky in this forum
      True T.
      My blog
      Nov 2003
      michigan
      Ive welded trim holes up. you usually start by sanding around the edge of the hole down to bare metal. then you clean the metal around it with a metal cleaner. then you begin welding starting on the edge of the hole (half on the metal, half off) like a 50/50 overlap and continue around the edge of the hole until its closed. kind of like a icecreamcone but not building up in the middle to high. small holes should only take 1or 2 passes and once it closed...leave the heat in the middle for a couple seconds and the build up will usually "drop" to be close to flush with the rest of the weld. dont hold it more than like 2 seconds or you will burn through.
      colt zantop
      westchester county new york
      Not a tutorial, but one tip is to do some bodywork and paint on a motorcyle tank or helmet, its a great small project to practice on.
      There never seems to be shortage of dinged tanks and helmets, just dont reuse a helmet with bondo on it.
      This link you keep you busy for at least a little while:
      http://www.camaros.net/forums/showthread.php?t=74560
      Oct 2005
      Odessa mo.
      I'll see if I can find some time to divulge some of my black magic secrets. Until then I will answer when I get time only if I feel I can answer 100% correct. I spend my days doing collision work but most of it is newer stuff on occasion I do some muscle car repair at home.
      NY
      Quote Originally Posted by Damn True
      if you have access to the back side of the hole, back it up with copper. The weld won't stick to it, and it pulls some of the heat from the base metal. (sort of)
      Pick up the book The Key to Metal Bumping it's over 50 years old, but the principles are the same. And the book explains alot about dent mechanics(?)
      http://www.eastwoodco.com/shopping/p...ProductID=1638
      Also, get GOOD tools. They're expensive, but they're made much better, and you will get much better results
      The needs of the many outweigh the needs of the few.
      Jun 2006
      TX
      Would you say that the tool from Eastwood are good tools?
      NY
      Quote Originally Posted by HotRod68Camaro
      Some of them, yes. The body tools they sell, are by Martin tools, and are excellent in quality.
