View Full Version : front too high
kman67rsss
10-03-2004, 05:27 PM
i installed DSE drop leafs and now that i have hung the front sheetmetal the front end is too high. i was thinking about cutting down the coil to get a little lower. is this a bad idea, or is it safe. main reason im thinking about this is because its free and i could use the money wiser elsewhere.
MoeBawlz
10-03-2004, 05:40 PM
unless its a progressive rate spring it should be ok...
baz67
10-03-2004, 07:02 PM
Yes cutting the spring will be ok. Just cut a little at a time with a cut off wheel not a torch.
Brian
CAMAROBOY69
10-04-2004, 05:25 AM
Are they the original front coils? The reason I ask is if they are new will settle after about 100-200 miles. Otherwise you will be fine cutting the coils.
kman67rsss
10-05-2004, 12:03 PM
they are the original front coils to my knowledge. maybee i will wait and see what happens
