    Results 1 to 5 of 5
      Suisun City, Ca.
      Proportioanl Valve Conversion
      I have a proportional valve, 5 port brass, 2 inlets 2 front outlets one rear outlet, originally for a disc front drum rear application. It reduced the rear brake pressure for the drums.
      Well now I have converted to front and rear disc brakes with a new master cylinder, and would like to use my proportional valve as a distrubution valve now, so the front and rear brakes get the same pressure.
      Is there a way to take out the inside parts so that this will deliver the same pressure front and back. That way I dont have to buy a new one.
      Mike
      Jul 2002
      Mesquite, TX
      Is there an access port that you can open to pull the guts out?
      If there's not, then the answer is likely to be "not really".
      What are you working with? Is your car a 50/50 weight car to begin with? Mid-engine? If not, a 50/50 pressure brake pressure system will put ya into a tailspin pretty quick.... -Jabin
      Gmachinz Sales and Performance
      "updating the level of performance..."
      [email protected]
      *never argue with an idiot-they'll drag you down to their level and beat you with experience!*
      May 2002
      Northern California
      Hi Mike, Hey Jab,
      Try using the set up you have now.If its no good then make changes.
      I just did a car and it works fine with the stock combo. Another car used a 3rd gen disc/drum prop valve and it worked nicely.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Suisun City, Ca.
      Thanks guys, and Vince I will do that.
      Mike
