    Results 1 to 7 of 7
      Oct 2008
      Toronto, Canada
      Interior rear view mirror wiring?
      I have re-worked a Donnelly auto dimming rear view mirror that I want to use in my 1st gen Camaro, having a hard time with the wiring configuration to hook things up. Tried Donnelly/ Magna which got me no where so I thought someone here might be able to help me figure the color coded wiring out.
      Name:  Mirror wiring.jpg
      Name:  Donnely interior rear view mirror.jpg
      Sep 2013
      Houston, TX
      I don't have a color chart but I've messed around with a few Donnelly lighted mirrors; I've found the wires on the LH side of the socket (in the back of the mirror) are usually the power and ground for the map light/dome light functions, the wires on the RH side of the socket are for the accessory features, i.e. temp/compass. You could open one of the map light sockets and test for continuity from the bulb socket to help narrow down the map light pins. Mirrors with only a temp sender use 2 wires from the sensor and are usually pinned at the far RH side of the socket.
      I have Donnelly #120187351 mirror in my 442 convertible. It doesn't have any additional features, just map/dome light function. My mirror pinned out as follows:
      Orange: +12v power
      White: Dome light ground, activates when the door is opened
      Black: Ground for individual map light function
      Rodney Meyers
      72 Olds 442 Rest-mod clone
      Oct 2008
      Toronto, Canada
      cdrod, thanks for the response, this mirror has the map lights that I want to function, the auto dimming feature is the one I really want. Do you know if any of the wires affect this function?
      We all have phones that help with other features that I don't care about on the mirror. I'll try some of your suggestions.
      Nov 2011
      Wylie, Texas
      Oct 2008
      Toronto, Canada
      Thanks for the schematic, I'll get some leads to the battery with a flashlight to see if I can get the auto dimming to function.
      Dec 2008
      Detroit
      Reach out to Bobs ....He might be able to help. I got a harness from him for mine.
      https://www.bobsmirrors.com/
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Oct 2008
      Toronto, Canada
      Thanks, I'll try him if all the other options don't work out.
