    Results 1 to 4 of 4
      Mar 2013
      n.london/herts
      Country Flag: UK
      72 firebird front coils
      hi..... fitted the lowering springs that came with the car (not sure what they are as no part numbers)...about an inch lower than the old ones but still about 1 1/2 inches higher than i would like..
      do I cut 1/2 a coil or replace the isolators with cut heater hose??
      Attached Files Attached Files
      Jun 2012
      South Lyon, MI
      Cutting a coil will increase the spring rate. Swapping the spacer would lower the car without changing the spring rate. I would try that first.
      Mountain Springs, Texas
      You could just eliminate the isolators.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Mar 2013
      n.london/herts
      Country Flag: UK
      heater hose should keep noise down? my 69 aint got any isolators!!!!!
