    Results 1 to 2 of 2
      Feb 2023
      Ride height 72 cuda
      Hello, I recently got into this hobby so I知 learning along the way any advice will help. But I知 looking to get this ride stance on my cuda but without doing a full chassis.. I知 planning on mini tub, spring relocation kit and shorty headers to get this stance.. my question is would it be drivable? I知 planning 20x12 in rear and 18x8 in the front like the picture above. Thanks again any help is appreciated!
      Jul 2022
      Michigan
      I don't see why you couldn't drive it what does the ride height measure at the rockers? really depends on the roads you drive on. For ground clearance looks like speed bumps might be an issue. Front suspension go lock to lock on steering during compression for fender clearance, that is where I'm at with mine. Should you go full compression, turn the wheels and cut for clearance or do a couple inches of compression then clearance.
