    Results 1 to 8 of 8
      Dec 2019
      Missouri
      69 Firebird Kick Panels.
      Hello. Help!!!. I have 69 Firebird. I have Vintage Air System with AC and heater. The lines are steel braided so not very flexible. The company doing my car already have them in. They come through where old blower motor was and through baffles behind kick panel location. They used the baffles that came with Vintage air kit. So the lines come through top of baffle with grommets in the baffles. The Shop LLC kick panels will not work like this. Does anyone know of kick panels that will work with speakers in them?. Or someone who makes them custom?
      Thanks Jerry.
      Quote Originally Posted by jtkkwag1 View Post
      Thanks Jerry.
      I am sure that any competent, local stereo installer can make you custom kick panels.
      Dec 2019
      Missouri
      Screamin performance
      Yeah. Wondering if anyone use screamin performance in theirs with vintage air? In either 67,68, or 69 Firebird or Camaro.
      Sep 2016
      Bakersfield, CA
      Glad I found this thread, I was going to order those kick panels as well.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      1992 Pontiac Trans Am GTA w/SLP Performance Package. Dark Jade Grey Metallic, grey leather, T-Tops.
      Dec 2014
      Rhome,TX
      I just ordered some kick panels from Classic Car Stereos.
      '72 Lemans
      468 Stroker; Aluminum KRE D-Ports ported by CVMS (10.2 comp); XR288HR Comp Cam; Port Matched Performer RPM; Quick Fuel Carb; Doug Long Tube Headers, 2.5 exhaust with H-pipe and Flowmasters; TH-400 w/11" 2800 stall; 9" Rear w/Eaton TruTrac Diff and 3.50 gears.
      Nov 2009
      Austin Texas
      You can still use the The Shops kick panels. You just need to drill your own holes in the inner cowl for the lines to pass though. I will try to get a picture of mine.
      Sep 2016
      Bakersfield, CA
      Quote Originally Posted by cwylie View Post
      Thanks. A pic would help a lot.
      Dec 2019
      Missouri
      But what if already have hoses installed the way vintage air says to do so?
