    Results 1 to 11 of 11
      Jan 2020
      Help with tires/size
      Just ordered 18x9 front 18x11 rear Rocket Attacks for my 66 chevy 2. Would like to run the same brand tire front & rear. Pretty set on 255/35/18 front. Car is mini'tubbed rear to the frame rail (13.5" clearance w/ springs inboard). Scratching my head over 295/35/18 (Continental Extreme DWS) or Hankook Ventus 295/40/18. Wanting a flush to 'some sidewall' look. Back & forth on overall section width of tire so I dont have the '96 honda 7" wheel with a 265 tire stretched look' lol. Anyone running the size wheel? 305, 315's with any type of sidewall are like dinosaurs....
      Jan 2020
      What does the front end have to do with rear tire size?
      Quote Originally Posted by Whiteghost66 View Post
      lol, took me a second to understand your question. That's just my signature. :-)
      Jan 2020
      Haha gotcha...was scratching my head for a sec.....pulled the trigger...went 255/35/18 fronts on 18x9 and 295/35/18 conti dws rears on 18x11....they are perfect. Will post pics once i get them mounted and on car at ride height. Firebirds are cool....
      On a '66 Chevy II that's going to look insane! My favorite year too (well that and '67 of course). Can't wait to see it.
      Oct 2018
      San Jose, CA
      Ya that’s a lot of rubber on that body style. Should be sick. Btw that’s the same ratio that comes on my Porsche Panamera 255/295 - it’s a nice split.
      1971 Camaro - 406 / T56
      2016 Camaro SS convertible
      2018 Colorado 4x4
      Jan 2020
      Ordered the wheels first and did a fitment check. With the mini-tub to the frame rail and the leafs inside, looks like the 18x11's are going to be perfect. At least 1" clearance on the inside and about 3/4" clearance outside. Quarters had already been rolled. Took my chances on the 18x9 fronts with 6" bs and only minor contact to the lca at full lock in one direction. Wont be driven lock to lock so not too worried. Wanted the full visual of the wheels so popped the center caps in and the rear wheels caps rattled. Called Rob @ Rocket and said may be a bad batch of o-rings on the caps so he is shipping new rings. If it ends of being a machining tolerance on the wheel, the rears will have to go back and be swapped. Cant mount tires on wheels til i know all is good. The 295/35 rears are going to fill the wells in the rear and the 255/35 fronts look great too. Painful to walk out in the shop and see the wheels & tires separated from eachother since i am waiting on the outcome of the rear wheel center cap dilema! Cant order my 9" until i can set my rear wheels/tires in the wells to get the overall width....More waiting!
      Jan 2020
      Couldnt wait....rough mock up just to get a visual. 255/35/18 front, 295/35/18 rear. Not at ride height yet, but close....Name:  20200220_140751.jpeg
Size:  59.3 KBName:  20200220_140900.jpeg
Size:  57.9 KBName:  20200220_140735.jpeg
      College Station, TX.
      What length did your rear come out to be? I'm looking at the G comp rear suspension for my 67 and the rear is 54" hub to hub an I was trying to see what wheels/offset wold work.
      Jan 2020
      I was 55 1/8 wheel mount surface to mount surface. Ford 9". Rears are 18x11, 6" bs
