    Results 1 to 4 of 4
      Dec 2011
      new york
      Dakota digital gauge issue
      Good evening, I have an 85 cutlass that had a 5.3 and working Dakota digital gauge cluster. I swapped out the 5.3 for an ls3 and the same gauge cluster. Everything but the engine and ecu remained the same. I have switch power, constant power and ground, but my gauges do not work. No led on the controller either. Everything seems to be plugged in as before. Any ideas
      Jacksonville, FL
      Did you connect batt, ign and ground to the control panel?
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Dec 2011
      new york
      Batt, ign and ground are to the controller, the cat 5 cable is attached to the controller and the gauge.
      Dec 2011
      new york
      Turned out to be a bad cat 5 cable
